Swimming pool design
Old Jul 15, 2007 | 05:19 PM
  #21
CG's Avatar
CG
My pool temp was up to 91 degrees yesterday. Feels like a hot tub. It is a lot of work to keep up but we love having it. It's used most days from spring through fall.
Old Jul 15, 2007 | 08:52 PM
  #22
RebelS2k's Avatar
Idk about y'all but our pool isn't that hard to keep up at all, and i live right on the water so i get crawfish and fiddler crabs that crawl up into it. Just get a polaris and you're pretty set straight lol.. also, do you guys still use chlorine?
Old Jul 15, 2007 | 09:59 PM
  #23
The Gasman's Avatar
I couldn't get a better picture, but Nikki Sixx of Motley crue has a vagina shaped pool.
Old Jul 16, 2007 | 08:28 AM
  #24
C U AT 9K's Avatar
We use those chlorine tablets. The biggest pain is keeping your pool clean after it rains. A little bit of precipitation and your pool turns green
Old Jul 16, 2007 | 08:55 AM
  #25
CrazyIvan's Avatar
The worst things about odd shapes is cost and it can eat up your actual swimming area a rectangle is probly your best bet with that you can also get a automatic cover for a more reasonable cost and it will cut down on chemical cost , cleaning time,and you can take the key with you so people can;t get in when your not there.
To the person I quoted your chemicals must be way off if turns green every time it rains. The tablets you are using may have your stabilizer (conditioner) to high or your chlorine left may be to low you should take a water sample to a pool store you trust and have them run a few set of test on it.
Old Jul 16, 2007 | 09:02 AM
  #26
AGBLLET's Avatar
I have had a pool for many years. It is a large kidney shaped one that I rebuilt a couple of years ago. The salt chlorination system is tops. The pebble tech finish with abalone shell mixed in is gorgeous. The rock features placed in the pool at the outside position of the baja step along with the boulders placed along the bigger edges of the pool are terrific accents and allow additional privacy. My climate is probably similar to yours - swim months may - oct. The goldens jump in it 365.
Pool heaters - solar don't work that well and are very expensive to install. Electric heaters cost a small fortune to heat and maintain the pool temp. Gas heaters would be the most efficient.
Recommend a stand alone above ground jacuzzi. Less expensive to maintain and movable upon sale.
hope some of this helps. good luck
  #27
C U AT 9K's Avatar
I guess I should have said we don't have someone constantly monitoring the pool, so if we show up sometime during the week after it rains, it's green.
Old Jul 16, 2007 | 09:20 AM
  #28
PDX S2000's Avatar
I like this design
Gymkata
Jul 1, 2010 09:16 AM
mxt_77
Jul 10, 2009 08:57 AM
