Preventing rips in soft top?
So I searched around and I couldn't find anything on it, but I know I've read about how most rips in the cloth tops happen where the cross bars are for the top and it rubs. Is there a secret to help prevent the rips from occurring? I was thinking about putting some sort of tap on the inside of the top but I didn't know if this would be a good idea or not. Maybe someone has a good link I should check out.
Thanks in advance!
Luke
Thanks in advance!
Luke
there are some guys in the classified that sell some patches as well if you already have a hole. look up tphong in the classified section.. he has some available i think
Also, when lowering the top, be sure that the front/middle bar folds back. If it isn't doing it regularly, you can get stronger elastic straps through Modifry http://www.modifry.com/products/ctf/details.htm.
Originally Posted by TheLast13' timestamp='1345594231' post='21954658
I smoothed the bar out with some sand paper then stuck a piece of marine vinyl to the underside of the top where the bar would rub. No issues in the three plus years its been there.
Also, when lowering the top, be sure that the front/middle bar folds back. If it isn't doing it regularly, you can get stronger elastic straps through Modifry http://www.modifry.c...ctf/details.htm.
Mexs2k
Jan 20, 2022 04:22 PM
