S2000 Body and Paint Body kits, paint, ding repair and related discussions
Paint blooming
Old Dec 9, 2009 | 06:52 AM
pedrobaby77's Avatar
Default Paint blooming
I am trying to spray a wing which i have now done twice, i have all the equipment but my problem is the weather (im in the uk) so the paint blooms. When this happens is it just on the surface or is all the paint effected? I tried sanding the top layer off and buffing it up but it still looks like the 'milky' effect is there. Can you sand of bloom or does it require another respray?
I have a formula red s2000 if this helps any
cheers
Old Dec 9, 2009 | 08:26 AM
Vanishing Point's Avatar
Pictures of the surface would help in determining what would be the best recommendation, but I imagine your problems are related to temp./humidity issues.
Any chance you can supply a picture of the wing? Hopefully from that I can recommend the best recourse.
Old Dec 9, 2009 | 08:31 AM
drhess06259's Avatar
try using a dehumidifier in the room when you paint.
Old Dec 9, 2009 | 11:07 AM
I will try get a pic of it but dont know if this will show up, its basically just enough to throw the colour out so the red doesnt match. Its definetly temp/humidity that is causing the problem because i dont get this problem in the summer. Out the tin the paint looks perfect but by the time it drys the red looks a bit cloudy and lighter
Old Dec 10, 2009 | 06:54 PM
RedY2KS2k's Avatar
Forgive me if I'm stating something that's obvious to you, but you do understand that the S2000 red paint job involves red mixed into the clearcoat?
Old Dec 11, 2009 | 05:57 PM
babowc's Avatar
do you have an inline water/oil filter?
Old Dec 13, 2009 | 06:51 PM
freshs2k's Avatar
If the temperature is to cold you can use a infared heat lamp which dries the paint from bottom up.
Spies
Feb 12, 2012 08:47 AM
S2000_Havens
23
Mar 20, 2008 07:59 AM
Nottm_S2
Apr 8, 2007 01:26 PM
GTFCTIM
May 20, 2005 10:54 AM
SeanW
Sep 18, 2001 01:01 AM
