Powder Coating Valve Cover
Should i replace the seals, or should i take them off, powder coat, then put the old ones back on? i had the misfire issue a few months back so all my seals are relatively new. I was wondering if i can just pull all the seals off, then just paint it and stick the ones i had back on. If not, which am i buying from majestic? (i see the head cover gasket set for 20$) thanks
The VC gasket is reusable as long as you don't see any tears or rips in it. However like Moddiction posted above you will need new spark plug gaskets...since you will most likely damage the ones on the VC when removing them.
