S2000 Body and Paint Body kits, paint, ding repair and related discussions
side diffusers installing problem
Old Oct 11, 2014 | 12:49 PM
tekstyle's Avatar
Default side diffusers installing problem
Hello. I am the process of installing side diffusers but I can not find any information on what is the recommended method to attach it to the underside of the car. i read some people use double sided tape, which I will use to reinforce it but not as a primary method. what other ways are there. do you guys drill holes or do you use the premade holes with the rubber cover?
second question. the material i plan on using s 1/4" thick. there is a spine (lip of metal whatever you call it) which contains the jack point that extends 3/4 to 1" down. therefore, should I space the diffuser lower to make it flush with the spine?
thanks,
Old Oct 11, 2014 | 01:11 PM
kryptonite's Avatar
Member
Spotter
Some people drill holes, some people use double sided tape.
I'd not space the diffuser lower since you might damage them when jacking your car up.
Old Oct 11, 2014 | 07:44 PM
tekstyle's Avatar
if you drill holes. what kinda screw, inserts, tap, whatever do you guys recommend?
Old Oct 16, 2014 | 05:41 AM
jpembry's Avatar
Just some plain old self tapping screws work! I used those as well as 3M tape
B Ma
Nov 22, 2013 10:19 PM
s2konroids
Feb 22, 2009 08:15 AM
hamsterguy67
Mar 2, 2006 12:37 PM
Ooalloems2koO
Mar 19, 2005 07:10 PM
RUGBY
Jul 16, 2002 10:33 AM
