side diffusers installing problem
Hello. I am the process of installing side diffusers but I can not find any information on what is the recommended method to attach it to the underside of the car. i read some people use double sided tape, which I will use to reinforce it but not as a primary method. what other ways are there. do you guys drill holes or do you use the premade holes with the rubber cover?
second question. the material i plan on using s 1/4" thick. there is a spine (lip of metal whatever you call it) which contains the jack point that extends 3/4 to 1" down. therefore, should I space the diffuser lower to make it flush with the spine?
thanks,
thanks,
s2konroids
Feb 22, 2009 08:15 AM
