Differences in suspension
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Is there any difference in any of the s2000 models from 99 right through.....
I have front struts off an 05 and am just wondering if they are the same as on 03...
Any help appriciated....
According to the Offical Springs Thread, here are the spring rates for the various model years:
OEM Spring rates by year (front/rear)
MY00-01 = 218/291
MY02-03 = 240/230
MY04-07 = 256/207
MY08-UP = 274/225
MY08 CR = 375/264
MY00-01 = 218/291
MY02-03 = 240/230
MY04-07 = 256/207
MY08-UP = 274/225
MY08 CR = 375/264
I'm sure the dampers have been changed along with the spring rates but I can't find any info on it. it would make sense.
The difference between 240 and 256 is pretty small so I wouldn't worry about it.
Managed to get a second hand damper so all good so far....Fingers crossed.....
Think it came out of my99 but seems to do the job at present....
Good info here but springs alone don't do the trick. Honda made changes in the sway bars every time they change the springs. Let me see if I can find the info. If you looking to replace your springs with from a newer s2k ( or from a new to old that depends of your taste) you should do it with the sway bars to have a good balance
