Sponsored by: Sake Bomb
Need help guys
Old Jun 3, 2011 | 05:40 AM
JoeyBalls's Avatar
Default Need help guys
Hey. SO I just got brand new RE-11rs in the rear and I noticed that when I go WOT and am around 100mph, the car floats very badly, swerves, and feels very very unsafe. I am making around 400 FT/lbs of Torque, but have not noticed this before. My alignment is probably due for a new one. I am on stock Shocks (110,000 miles) and Espelir springs. I did notice that there are no weights on the rear rims, as it looks like the shop did not balance the wheels, but I don't know if thats the issue?
Anyway what should I do to try and correct this? I don't really want to spend the $800 for Koni Yellows and new springs, as I don't corner much (not easy with high HP), however if it's the only option so be it, the car rides like shit and is plain scary at 100mph
Old Jun 3, 2011 | 05:49 AM
hypforlife32's Avatar
When was your last alignment? That very well could be your issue. I don't think it's your shocks because you just changed your tires and now it's doing that. If there wheels where not balanced then you would have an un godly terrible vibration. The weights are either stickied inside the wheel or on the inside lip of the car also
Old Jun 3, 2011 | 07:28 AM
JoeyBalls's Avatar
I couldnt find the weights anywhere. There is no vibration, last time I had the car aligned was like 2.5 or may 2 years ago?
Old Jun 3, 2011 | 07:54 AM
chuhsi's Avatar
balance, alignment, and tire pressure
Old Jun 3, 2011 | 08:07 AM
JoeyBalls's Avatar
thanks, will do
Driv300mph
Nov 23, 2008 10:35 AM
99sss2k
Nov 13, 2007 04:06 AM
mkell
Dec 28, 2005 06:24 AM
xda2000
Oct 11, 2004 08:16 PM
dreamgetter1
Dec 17, 2003 10:15 AM
