Sponsored by: Sake Bomb
Is this normal?
Old Sep 9, 2014 | 06:43 PM
bgoetz's Avatar
Default Is this normal?
I am changing out my springs and was just curious as to if the holes where the upper a- arm mounts on the front suspension were suppose to be larger than the bolt going through. It really allows for a good bit of movement. Also the bolts themselves look odd, kinda grooved. Again maybe this is totally normal, but I wanted to be sure the original owner didn't put in the wrong bolts when swapping bushings and cause wear.
Old Sep 9, 2014 | 08:10 PM
bgoetz's Avatar
Other side looked the same, so either both sides are messed up or it is totally normal.
Old Sep 9, 2014 | 09:58 PM
flanders's Avatar
That looks like the correct bolts, they are grooved to keep them from seizing up.
As long as you torque them to spec I don't think there is any possibility of movement.
Old Sep 10, 2014 | 03:51 AM
bgoetz's Avatar
Ok thanks! Kinda what I figured, I just wanted to be sure. It seems to me that with the amount of play camber could really be effected when unbolting/rebolting the upper a arm.
Old Sep 10, 2014 | 05:59 AM
flanders's Avatar
Remember that the suspension should be loaded when torquing up those bolts.
Old Sep 10, 2014 | 08:06 AM
bgoetz's Avatar
Yes! Is there any need to loosen any of the others that I didn't have to loosen to remove the shock? I think the others are all adjustment bolts that will be adjusted when I get an alignment.
Old Sep 10, 2014 | 08:16 AM
flanders's Avatar
No you don't need to touch them, but if they never been removed it might be a good idea remove and grease them up.
It's very common that the lower bolts seize up and need to be cut out.
Old Sep 10, 2014 | 08:54 AM
bgoetz's Avatar
They have, the previous owner did all of the bushings. Anti seized the hell out of stuff, which I love!!
Old Sep 28, 2014 | 07:27 PM
darcyw's Avatar
that is a real Honda bolt with the grooves on it. Honda makes some really excellent bolts that are pretty pricey.
darcy
Johnmassey
May 4, 2018 04:45 AM
GreenmanS2000
Feb 25, 2015 10:59 AM
FISH22
Aug 24, 2006 01:26 PM
Rhino80
Mar 3, 2006 03:49 AM
dookiewhat
Mar 2, 2005 05:17 AM
