Suspension Stock vs Aftermarket
http://m.youtube.com/watch?v=Nl5cFzc...%3DNl5cFzcZ8YY
After driving my stock ap1 for about six months now as a DD. I was wondering how much of an improvement could be made to this cars handeling with aftermarket suspension? I feel that I would make it worse for street driving changing from stock. Seems to me it's more just for looks. Anyone have regrets changing from stock?
I was watching the youtube video above and feel that I have not yet tapped into understanding the stock s suspension yet. I guess I need to find a track.
Get the car to a track first with stock suspension. Its a lot of fun left alone and it frees you up as a driver to work on yourself instead of trying to learn AND tune the car. I tracked mine for 2.5 years on stock suspension and its a LOT of fun.
I would recommend a good alignment and brake upgrade (pads/lines/fluid/ducts) LONG before I would advocate messing with the suspension.
Thanks I will keep driving it the way it is and try to find a track in southern CA.
The car had aftermarket drilled and slotted brakes calipers on it when I got it they look larger in dia than oem. Not sure what kind they are but in new condition.
The car is stock except for:
Brakes,exhaust and gutted oem airbox.
I really like the stock suspension. I use to have tein flex coil overs and after switching back to the stock suspension I enjoy my car so much more on the street. My times when I go auto crossing is also faster with the stock suspension.
With my tein flex the car was too bumpy and unconfertable to drive everyday 15k+ miles a year. The car with an oem lip is already low as he'll with stock suspension. Good luck going up driveways and gooding past speed bumps on a lowered s2000 with a lip.
Since camber is adjustable in stock form you can improve your handling a little with a good alignment.
My AP1 has 96k miles on it, so I'm going to be replacing the bushings, stiffening up the chassis, and replacing engine/trans/diff mounts this coming spring. To get it to the track initially last summer I added brake lines, pads, rotors, brake fluid and tires. Honestly that was enough to be fast, safe and fun.
Whatever you do - Enjoy!
Thanks everyone and the ride offer s2ka I'm gonna stick with the stock setup. I just like the way it feels. I do have the oem lip and a bad driveway so lowering is a bad idea as much as I like the look.
s2ka I'm in san clemente and good for a drive anytime work up in Irvine drive there most everyday.
Thanks all!
Thanks all!
