Sponsored by: Sake Bomb
Swapped Left/Right CV cup swap
Old 01-08-2022, 08:22 AM
soccaz34's Avatar
Default Swapped Left/Right CV cup swap
Had a repeating thud/vibration on throttle at higher loads, it seemed to be the worn out CV joint. I performed the CV swap left to right and I did see damage on the driver side CV joint as I have seen in Youtube videos. After doing the swap, now the thud/vibration is at twice the frequency and at even lower throttle applications, basically things became worse than they were. I am not sure what could've cause as everything was torqued/etc. I labeled the CV joints before I took the out to make sure not to mix them up either.
P.S. I also get a loud click now, which seems to be the undertorqued Axle nut issue, but I never even touched the Axle nut.
Old 01-08-2022, 02:07 PM
noodels's Avatar
maybe have already been swapped
Old 01-08-2022, 03:43 PM
soccaz34's Avatar
They haven't, because I inspected both CV cups and only had any damage at all.
dsthez
04-06-2012 07:28 AM
dsthez
02-24-2011 12:32 AM
AusS2000
03-16-2009 06:06 PM
gota
01-15-2009 01:48 PM
Gernby
08-12-2005 11:34 AM
Quick Reply: Swapped Left/Right CV cup swap
