2002 speaker question - need help
Old Jan 26, 2002 | 04:04 PM
Jaysom's Avatar
Default 2002 speaker question - need help
I'm in the process of installing new speakers in my 2002 and was wondering if anyone knew the proper way to install seperates. I noticed once I had the door panel off, that both the mid bass and tweeter have an output connection. My question is ... when using a crossover, do you only connect the factory output from the mid bass to the crossover "input" or do you also connect the tweeter output as well - meaning do I run wires from both the mid bass and tweeter to the crosover "input", Or only run a wire from the mid bass output to the crossover "input" Hopefully this makes since .... need some advice.
Thanks for any help!
Old Jan 26, 2002 | 08:59 PM
Nside's Avatar
Why use the crossover? If you connected both tweeter and woofer wires to the input all the crossover does is split the signal back to low and high. I'm not a stereo person, but using the crossover doesn't make sense to me...
Old Jan 26, 2002 | 09:09 PM
matrix's Avatar
DO NOT do this, you will basically be putting the speakers in parallel and the tweeter will not be protected, you WILL blow it.
Connect the wires from the H/U to the xover input. Run the xover outputs to the appropriate speakers...i.e. mid bass out to mid bass speaker, tweeter out to tweeter. Here is a quick pic.
Take care to ensure you get the polarities the same.
Hope this helps.
Old Jan 27, 2002 | 06:13 AM
Jaysom's Avatar
Matrix,
Thanks for the help I went ahead and connected as you described ... sound isn't to bad, but only currently using the stock head unit for power ... Amp will be next weekends project.
One option the crossover has is an output for "rear fill" not sure if I use this or not, but I thought it was a neat feature ... maybe this is standard now, I have been out of car audio for sometime now.
Anyways, thanks again for the info.
Old Jan 27, 2002 | 07:33 AM
matrix's Avatar
Glad I could help. When you get your amp, if you have any questions...just post .
msculptor
Jan 31, 2011 11:16 AM
jwh445
Feb 29, 2008 03:01 PM
jdmcrave
Jul 22, 2006 09:22 AM
J Nick
Nov 11, 2003 02:11 PM
Gioire
May 15, 2003 08:23 PM
