Alarm uninstalled, now power lock dont work!
Old Nov 22, 2010 | 07:00 PM
etang789's Avatar
Default Alarm uninstalled, now power lock dont work!
After spending 3 long nights, I have successfully uninstalled the alarm that the previous owner installed ( Clifford 50.5x and Immobilizer Securitech (Asia) Ltd. TES-761 Immobiliser ); well at least the car started back up and everything running except the power door locks.
I have traced every wire and disconnect them and return them to original form.
My question is how does the stock power locks react when you insert a key to unlock the door? There seem to be no power to the lock motors at all, and seem stiff to lock the doors manually from the inside...And where should I look to solve this problem? Did I remove 1 extra relay? ( I dont have OEM Honda Alarm)
I have removed 3 sets of relays. 2 being behind the driver seat, and 1 under the dash.
I assume:
1 is Fuel Cut relay
1 is Trunk Release
1 is Door locks???
I will look into the doors this weekend and see if they did something at the doors.
Old Nov 28, 2010 | 10:30 AM
etang789's Avatar
Ok problem solved!
apparently the previous installer changed around the wirings in the driver door. I guess the previous installer could not figure out how to wire to the door locks correctly...sad
User 4225
Oct 1, 2015 12:23 AM
lopez14
Sep 16, 2012 07:52 PM
vstypicals
Mar 6, 2011 06:10 PM
splatter85
Jun 17, 2009 08:08 PM
whites2ooo
Mar 28, 2003 02:21 PM
