Alpine 9883 - fitment and ipod questions/issues
Old May 28, 2007 | 12:25 PM
GTScott's Avatar
Default Alpine 9883 - fitment and ipod questions/issues
I recently installed the Alpine 9883 with the iPod cable in my 2007. I am now having two issues...
1) iPod - I did not realize it, but the Alpine cable does not charge the iPod. No big deal. However, I have noticed that if I am listening to the iPod and turn the car off, the iPod stays in play mode and does not turn off. If I turn off the head unit or even switch to a different source it does put the iPod in pause mode and thus turns it off. Is this normal? It just seems like somewhat of an issue to have to remember to always switch sources to avoid having the iPod continue playing.
2) Fitment - I imagine this is caused by my last minute install technique, but does anyone else have issues with the card holder section of the stereo door depressing the volume knob when you push in on the door to access the stereo? If I push on the far side, it is not an issue but near the knob it is. I am guessing that I just don't have the stereo tightened in far enough as it is just BARELY touching the knob when depressed. Anyone?
Thanks!
Scott
Old May 28, 2007 | 12:41 PM
Romeez's Avatar
Gt Scott,
Something is wrong with the ipod and fitment. I have this same deck and
1) the cable charges the ipod and when the car turns off the ipod does as well
2) the deck should fit perfectly, mine does not touch or interfer with the radio door.
Something is not right! Did you have it professionally installed and what cord are you ruinning? The deck fitment issue sounds like it was mounted incorrectly.
hope this helps shine some light on the isues you are having!!
Old May 29, 2007 | 03:43 AM
GTScott's Avatar
Thanks for your help! As for the fitment, I was rushed when I was putting the unit back in and assumed it was my problem but wanted to confirm that with someone - thanks!
As for the iPod, I have the Alpine 422i cable. When I called Crutchfield, the tech support person also said that it did not charge the iPod. On their site, it does not mention charging but does mention it for some others.
http://www.crutchfield.com/S-OAxv39gyg5V/p...sp?i=500KCE422I
As for it not turning off when the car turns off, that one baffles me. It does the same thing with two different iPods of different vintage but both running the latest updates.
Old May 29, 2007 | 12:40 PM
w0rdie's Avatar
My 422 charges my iPod, is the deck an 06/07 deck?
Old May 30, 2007 | 03:30 AM
GTScott's Avatar
Now this is getting interesting. Crutchfield said that it does not charge it but everywhere else I look says that it does. When my wife turned off the car and the iPod kept playing it drained the iPods battery. I wonder if it just charges when the car is on and hence when the car is off and the iPod keeps playing it drains its battery. That might explain that one.
On your 9885, if you leave it on the iPod source and turn the car off does your iPod go into pause and then turn off like it should?
Old May 30, 2007 | 09:04 AM
NOMOREBOOST's Avatar
I have a 9885 and when i turn off the car the ipod pauses and turns off...
it does not matter what source i use.
parkerdt
Jun 25, 2008 05:52 PM
shamoo
May 28, 2008 11:02 PM
NATURAL JOCK
Jul 14, 2006 08:15 PM
simon737
Jul 11, 2006 11:39 AM
yoweichang
Mar 21, 2006 11:08 AM
