Alpine CDE-147BT
Old Apr 22, 2013 | 01:00 PM
JD NC's Avatar
Originally Posted by rtm5003
Right - they released the iPhone version of the app on the same day as the 147BT itself, but the Android app is lagging behind. They expect to have this wrapped up by the end of the month. Once that happens, I'd be happy to upload some S2K-specific settings for y'all.
I should be installing the HAT Imagine's, Alpine Power Pack, and Damplifier Pro this weekend. These stock speakers are useless!
Nice. I installed polk db6501s a couple months back, but I'm already itching for the HATs. Good to know that they'll be EQ presets waiting for me when I upgrade
Old Apr 22, 2013 | 05:37 PM
Chris Stack's Avatar
Anyone know if/when this will be at Best Buy? I have a $240 gift card from selling back a phone and I want this to replace my aging CDA-9885.
Old Apr 22, 2013 | 05:39 PM
Originally Posted by JD NC' timestamp='1366552125' post='22488383
Nice. Have you used the new TuneIt app with it? Alpine released it for these newest head units and it will let you share eq settings and import them from other people with the same car and gear setup. About a dozen s2ks are listed in the app so far, but no ones sharing any settings yet, probably because the compatible head units are only just now shipping.
Do you know the order of how to install the power pack wi the modifry harness? Are you using the universal one that can be bridged?
Old Apr 22, 2013 | 08:35 PM
1stS2k's Avatar
I had my mic mounted at the top of the A pillar, using the provided clip, one end goes behind the A pillar at the top and this way the mic faces you. Haven't tried it with the top down yet.
Sent from my iPhone 5 using Tapatalk
Old Apr 23, 2013 | 03:07 AM
rtm5003's Avatar
Originally Posted by Chris Stack
Originally Posted by rtm5003' timestamp='1366654212' post='22490701
[quote name='JD NC' timestamp='1366552125' post='22488383']
[/quote]
Yep- they are only making the universal version right now. But I figured it'd be better in case I wanted to move it to a different car in the future.
The power pack manual can be found here. There are details on how to wire it.
http://support.alpine-usa.com/produc...M_KTP-445U.pdf
You just need to run one set of RCA's (fronts,) power, ground, remote, and the 4 speaker wires (bridged.)
Then wire in the five required DCI wires to this harness and you're done!
Old Apr 23, 2013 | 03:11 AM
EP Heart's Avatar
They announced the KTP-445A at CES that makes it PnP with Alpine headunits again. The vendor I spoke with just started getting them in stock. KTP-445U is the universal one.
Old Apr 23, 2013 | 03:41 AM
But the A isn't bridge able, WTF alpine??
Old Apr 23, 2013 | 09:10 AM
oth's Avatar
oth
FWIW, the KTP-445A likely is bridgeable, as it is listed as being 2-ohm stable (a prerequisite
for bridgeability) unlike the original KTP-445. However, as it comes with a plug&play 4-channel harness
for Alpine, it isn't wired for bridging. It might be nice if they included two harnesses, one bridged,
but it's easy enough to just use the KTP-445U, or you could cut & splice the 445A harness.
Old Apr 23, 2013 | 09:51 AM
rtm5003's Avatar
Right... Crutchfield shows the A shipping 5/10.
The U has a switch on the side of it to select between 4-channel and 2-channel input mode. I wonder if the A will have this switch.....
Since I'm planning on running new speaker wires to the doors as well as a direct 12ga wire to the battery, I don't really see the advantage of the A, even though I'm using an Alpine HU... the only wires I need to run to the HU are RCAs and remote.
Old Apr 23, 2013 | 11:22 AM
If you're going to do all of that, I guess I don't see the point of using the Power Pack. Why not just a regular amp?
