Alpine wired DCI
Old Sep 26, 2005 | 10:24 AM
AZRX's Avatar
Default Alpine wired DCI
I just got a new alpine head unit (9855) and wanted to wire the controls by the steering wheel to work. I looked around and found out that the new Modifry wired DCI will work. I definitely want a wired DCI opposed to a IR one. Does anyone have any experience good or bad with the Modifry wired DCIs and the new alpine units? Do I need/should I get the harness adapter that is available for purchase with it? Are there any other wired DCIs that will work for the Alpines? Thanks for the help.
Old Sep 26, 2005 | 08:30 PM
Nugget's Avatar
I am also interested in this topic, because I am going to be purchasing an Alpine 9855 head unit and the modifry wired DCI as well in the very near future.
Thanks
Old Sep 26, 2005 | 09:22 PM
mega's Avatar
Im using the PAC wired unit. and i do have that deck 9855. i have no issues with the PAC, but modifrys DCI has one feature i like, variable speed volume.. both are good btw. ;-)
Old Sep 27, 2005 | 04:40 AM
RST's Avatar
RST
Hi guys
Although i live in the uk i have installed an Alpine 9855 HU with a Modifry DCI and connected the speed control wire. It works perfectly and gives me extra functions that the origianal dash controls did not have !
Hope this reassures you
Old Sep 27, 2005 | 10:27 PM
Sparky2k's Avatar
RST,
I am looking to do the same and have the same question as AZRX asked above, "Do I need/should I get the harness adapter that is available for purchase with it?" Did you use the harness adapter?
Old Sep 28, 2005 | 09:08 AM
AZRX's Avatar
I ended up just buying the Modifry wired DCI and harness since it sounds like everyone that has it is happy. Hopefully I will install it this weekend if it gets here in time. Once its in I'll let you know what I think and if you need the harness. From my understanding the harness adapter saves you the trouble of splicing wires for some of the functions of the DCI, but I could be wrong.
Old Sep 28, 2005 | 01:59 PM
RST's Avatar
RST
Post
Yes get the harness adapter with the DCI
It will save you splicing the honda wiring loom or the alpine connector loom.
I would also reccomend that you connect the speed volume control wire as this will save you continually adjusting the volume manually.
The 9855 is a huge improvement over the stock head and if you go for the ipod option you will never regret it, as you suddenly have music for all moods.
Old Sep 29, 2005 | 05:10 PM
jimmied's Avatar
i have already purchased and installed the Modifry wired. like it a lot. no problems. i didnt use the speed sensor
switchmorgan
Nov 22, 2013 02:44 PM
kiddiosky
Jan 10, 2012 11:16 AM
lawerence
Jun 5, 2007 03:19 PM
vinasity
Feb 9, 2006 12:34 PM
pikkashoe
Nov 30, 2004 06:14 PM
