alternator whine in car speaker
Old Jun 3, 2011 | 05:05 AM
SIchodelic's Avatar
Default alternator whine in car speaker
where could it be coming from?
My power cable runs along my fireball then enters the driverside firewall near the pedals. it is then ran behind the driver seat, then crosses behind the glove compartment, around the spare, and finally to my amp in the trunk
my RCA cable goes from behind the HU to the passenger side where it runs below the door sills, back into the cabin behind the seats and then to the amp in the trunk
never do they cross and im still getting the alternator whine...any ideas why?
Old Jun 3, 2011 | 07:29 AM
oth's Avatar
oth
It's probably a problem with your amp's ground connection.
Old Jun 5, 2011 | 11:22 PM
Ragnarok043's Avatar
its actually okay for RCA cables to cross power cables at 90 degree angles, just not parallel. anyways you could be getting electrical interference from other oem electrical components(such as the fuel pump) that may have power wires running along the passenger door sill. do you also have any extra RCA slack coiled any where near other electrical components. to test this out try running the RCA cables directly from the headunit to the amp with out tucking it under the carpet and panels.
Old Jun 6, 2011 | 03:40 PM
SIchodelic's Avatar
hrmm
could you give me some more information about this?
edit:
interesting, did some google searching about alternator whines and bad grounds
sounds like a grounding loop is what im experiencing
zhp43867
May 5, 2010 05:31 PM
h22boy
Jan 24, 2007 02:51 PM
golfpro
Jul 29, 2006 10:53 AM
tripod
Aug 10, 2001 01:47 PM
dirt
Jun 26, 2001 02:44 AM
