Amp blew fuses then turn signals wont work
Old May 19, 2009 | 02:16 PM
s2kattack's Avatar
Default Amp blew fuses then turn signals wont work
anyone had this problem? this is not on my s2000, its on a 03 civic si.
it is not the 7.5 amp fuse for the signals, it isnt the underhood fuse.
im about to order the relay but i figured id ask before i spent the money
Old May 19, 2009 | 03:22 PM
Stealth_SUX_'s Avatar
how would an amp blow ur cars fuse unless u have ur power wire hooked to like the fuse box instead of the battery.
Old May 19, 2009 | 03:42 PM
s2kattack's Avatar
it shouldnt. im just wondering if anyone has had a relay coil burn up before the fuse (that is supposed to protect it) blows.
somehow something in my wiper circuit got surged with more amps than normal, or maybe just by chance a relay went out at the exact time i hooked the amp up. thats unlikely
just wondering if im missing something here. just doesnt make sense especially since it is in a entirely different circuit.
s2kattack's Avatar
this is probably in the wrong thread. maybe under the hood would be better?
Old May 19, 2009 | 07:33 PM
2big4aS2000's Avatar
i would check you grounds in that car - battery to frame, engine to battery, engine to frame.
Old May 20, 2009 | 05:29 PM
GrandMasterKhan's Avatar
who installed everything? Are you running the OEM headunit? If not then someone is probably getting amp turn on from somewhere they shouldn't.
Old May 22, 2009 | 12:51 PM
drewmob's Avatar
Is your remote power wire for the amp hooked into your fuse box? if it was hooked into the wrong side of the fuse and came in contact with your power wire its no bueno...
s2krey
May 9, 2008 02:10 PM
droo587
Mar 16, 2008 09:50 PM
cshamash
Mar 4, 2006 08:22 AM
sweetj
Oct 14, 2004 07:09 AM
Goldtrom
Jul 23, 2001 02:30 PM
