amp board for spare tire
Old Jan 6, 2002 | 02:33 PM
J MAN's Avatar
Default amp board for spare tire
I know I saw someone in here that was selling pre made boards that fit inside the spare tire. I'm trying to fit an 11 1-/2 x 11 3/4 amp in; any help would be appreciated.
Old Jan 6, 2002 | 04:28 PM
Alister's Avatar
With the right equipment (ie jigsaw), it is very easy to do yourself. All you need to do is get some MDF from your local hardware store and measure up the dimensions. It is probably worth squaring off one edge so that you can still easily remove the spare tyre/tire.
I made a board up for my PPI amp and mounted it in the spare tire. I am happy with the install as you would never even know that it is there, and retaining boot space was a priority.
Old Jan 6, 2002 | 05:28 PM
matrix's Avatar
Get a rotozip with the circle guide, you can then cut a perfect circle to fit inside the rim for your amp board.
Old Jan 9, 2002 | 03:56 PM
J MAN's Avatar
I found out that the amp I got from a friend; an kenwood ps200; is designed with angled corners to fit in a spare perfectly. I installed it today and it fits like a glove. Appreciate the info anyway.
Old Jan 11, 2002 | 01:33 AM
stevenleith's Avatar
Is it possible to put an amp board next the spare wheel - the fuel tank's in there isn't it!?!
Old Jan 13, 2002 | 11:55 AM
What The's Avatar
Or how about removing the spare tire?
There's not much room to work with on the left side.
Old Jan 13, 2002 | 01:12 PM
I am very glad you posted that photo cos it helps with visualising exactly how i can set up that space!!
You got a cap on them amps?? My two amps are putting out about 700RMS so not sure whether to install the cap. I already have it so i suppose i may as well - it might help with the bass response.....
How is the board held to the floor??
UberDuper
Aug 28, 2015 07:54 AM
philbert
Jul 27, 2007 07:35 AM
ptsmalls
Feb 20, 2006 08:28 PM
Ajjra
Oct 5, 2004 06:26 PM
Waterbug
Jan 9, 2004 09:01 PM
