amp recomendation please?!?!?
Old Dec 27, 2012 | 08:55 PM
chefs2000's Avatar
Default amp recomendation please?!?!?
hey guys just blew my amp ......i have a 10 inc jvc aw8040.. its continuous 1000 watts rms and peak 3000 watts.... its dual 4 ohm... i dont really understand the what it means to have 4 ohms instead of 2... do i need a specific amp? any help ide appreciate thanks
Old Dec 30, 2012 | 10:22 AM
oth's Avatar
oth
Dual 4-ohm means it has two voice coils, each of which is 4-ohm. It can be wired up
either in series, in which case the impedance seen by the amp is 8 ohms, or in parallel,
in which case the impedance is 2 ohms.
Amps with unregulated power supplies (which is most of them) will produce more power
into a lower impedance than a higher one, so you would likely want to wire it in
parallel for a 2-ohm load. But that means you need to find an amp which is capable
of driving a 2-ohm load. Most amps can do so unbridged, but relatively few can when
bridged. If you stick to a mono sub amp you'll likely be fine, but you need to read
the specs carefully if your plan is to bridge a two-channel amp.
HTH
DFWs2k
Aug 22, 2008 07:55 PM
crav3s2k
Jun 10, 2008 07:50 PM
Boost76
Feb 15, 2008 07:35 AM
MIC
Mar 15, 2004 09:04 AM
drivebynature
Nov 20, 2003 02:18 PM
