Amp under seat
Old Mar 11, 2009 | 10:37 AM
S-FLY's Avatar
Default Amp under seat
Does anyone know if an amplifier will fit under the seats? If so, what is the maximum height for an amp to fit, I know it can't be much!
Thanks!
Old Mar 11, 2009 | 12:36 PM
Crackerballer's Avatar
Well I know some do, and there are plenty of people who have done it. I am trying to put one under the passenger seat, but I got a larger one (like 2.5" thick" and I don't know if it will.
Search, a lot of people have done it.
Old Mar 12, 2009 | 09:11 AM
Supersport's Avatar
Mine is under the passenger seat and it BARELY fits with dimensions of 13-1/2" x 9-5/8" x 2-1/8".
I had to slide the seat all the way forward; bolt down the back part of the seat. Then, while lifting the seat up slightly, slide it all the way back and then bolt down the front part of the seat over the amp. However, you can't adjust the seat one bit so it remains in the all the way back position.
Old Mar 12, 2009 | 09:14 AM
That's good to know, mine is Dimensions (L x W x H) 12-1/4" x 10-3/8" x 2-1/8 according to JBL's website, and I thought maybe I could cut the carpet to gain a little more clearance.
Old Mar 12, 2009 | 01:04 PM
woogie's Avatar
Genesis Profile Four,
Genesis Profile Two Ultra,
Genesis Profile Two
Genesis Profile Sub,
Thickness of these is 38 mm, and You need to cut a carpet out too.
also some of Helix amplifiers could fit.
Old Mar 12, 2009 | 02:08 PM
DFWs2k's Avatar
I have a kenwood that fits under the driver's side. Not sure on the size, it's only like 250w though, I only use it for the speakers, car is at the body shop, otherwise i'd get the model number and measurements for ya...
Old Mar 13, 2009 | 11:31 AM
Supersport's Avatar
You could gain some more by cutting the carpet. I didn't cut mine; just drilled some holes in it.
senfinger
Mar 21, 2006 05:39 AM
formulaofsuccess
Aug 27, 2005 11:23 PM
Fusiondynamics
Oct 20, 2003 08:23 PM
Whatelse
Oct 12, 2002 09:42 AM
Mike L
May 28, 2001 02:57 PM
