Amp under seat? maybe?
Old Apr 22, 2003 | 08:42 AM
  #21
jsadlers2000's Avatar
ok.. i also found a rockford fosgate power 450 s that looks like a good quality amp that runs 112 x 2... and a kicker kx400.2 that runs 100 x 2.. out of those 2 amps and the PPI... which amp is the best quality
Old Apr 22, 2003 | 12:08 PM
  #22
dreamcation's Avatar
Why would you want the amp under the seat,? You'll have to keep the AC running all the time to accommodate for amount of heat you'll be producing with that amp.
Old Apr 22, 2003 | 02:48 PM
  #23
Tiger8119's Avatar
uh no you wouldn't
Old Apr 22, 2003 | 02:54 PM
  #24
i figured the inside of the car would be generally cooler than the trunk (with no air at all)
Old Apr 22, 2003 | 03:06 PM
  #25
mas's Avatar
mas
Search thru previous posts on the electronics forum, I'm sure some people have installed amps under the seat. It will be much easier to order one that someone has already installed under the seat so you don't have to worry about dimensions and overheating, etc.
The PPI amps run pretty cool but I'm not sure about size. Actually, I can go check for you since my amp is out right now.
Old Apr 22, 2003 | 03:13 PM
  #26
sorry, couldnt wait any longer.. purchased the Kicker KX400.2.. hope it works.. and i hope itll go under my seat.. thanks for everyones input.
Old Apr 22, 2003 | 03:25 PM
  #27
mas's Avatar
mas
That's good, cause the PPI does not fit, I just tried.
Good luck with the install!
Old Apr 22, 2003 | 04:01 PM
  #28
thanks for your help man
Old Apr 23, 2003 | 09:46 AM
  #29
I was not referring to the amp overheating but rather the overall heat with in the cabin of your car.
MurderS2K
Feb 23, 2010 08:53 PM
Boab01
Mar 7, 2008 02:22 PM
gotswap
Nov 18, 2006 01:51 PM
Mocky
Nov 2, 2004 11:56 AM
FRCHNDN
Mar 12, 2001 09:50 AM
