Amplifier location
I had just recently had a small JL audio sub/amp installed and the person who did it has the amp laying in where the jack and tools are... like right in the middle. When i got home I was messing around with it and the amp is HOT...I couldn't leave my hand there on it for more than 2 seconds. It doesn't seem like It should be that hot... Is this safe or no?
what amp are you running? class a/b or class d? what's the ohm rating? maybe consider upping the ohm's to run it cooler. do you have any sort of bass booster on? check your gain settings and maybe consider lowering them a bit as you could be pushing your amp too hard. just off the top of my head. may or may not be releveant.
I used a bolt to hold the arm, a plastic plug to hold it steady (can se the support on the right side in the picture).
If this is a good solution or not I can not really say, but it has worked so fare
The result:
https://plus.google.com/u/0/photos/1...24414426284866
The arm holding it:
https://plus.google.com/u/0/photos/1...24410754979346
https://plus.google.com/u/0/photos/1...24412362795217
Maybe the amp is under-sized for what you're dong with it? Or maybe the power wire is under-sized, which on some amps can cause it to draw more current as it tries to make up for the lower voltage.
That said, what exhaust do you have? Placement of the mufflers and how much heat they release on some non-stock systems can make the lower part of the trunk very hot, especially if the car idles for a long time (no air flow).
