Android Single Din w/o Cutting!
Old Jun 6, 2021 | 10:13 AM
  #201
toecheese's Avatar
Originally Posted by slam126
Look on this thread post #40. That’s how you get mute to work.
Thanks - yeah I realize a relay will make it work, but it's not worth the bother for me. I almost never used the mute button when it did work. But all the other functions that do matter to me work with a simple hardwire to the Joying, without any relays or interface adapters needed.
Old Jun 6, 2021 | 10:14 AM
  #202
toecheese's Avatar
Originally Posted by Slapasaurusrex
Is there any way you could send me these files or print them for me? Ill pay! Thanks!
I sent you a PM - I can email you the .stl files if you still need them.
Old Jun 6, 2021 | 10:32 AM
  #203
toecheese's Avatar
Originally Posted by oth
I'd be careful about just experimenting with switching wires -
the dash switch wire goes to ground (-) while the mute
switch wire supplies +12v.
You are correct. I looked up what I did on my install, this works:
Connect harness pin 3 to the Joying wire labelled Key 1. THAT'S IT. If you connect the pin 14 mute wire to key 2 without a relay you will get all kinds of crazy behavior where the dash buttons start doing different things like the OP describes. Once I disconnected Pin 14 entirely, mute will not work but the rest of the controls work perfectly. I've had it for 6 months with no issues.
Old Jun 6, 2021 | 10:37 AM
  #204
toecheese's Avatar
Originally Posted by silenc3x
No, been waiting... dreading having to reinstall all my shit, but I will soon.
I hear it improves the dashboard control interface. Which may help with an issue I face, which is that sometimes pressing the volume up button will press the MODE button instead. I used to have that binded to NEXT TRACK but it was too annoying since I would go to increase the volume and occasionally it would change the track. Now that button just brings up Android auto, so its not the end of the world when it mispresses.
Did you ever install the firmware update? I read there were some google account login issues with it, which they have supposedly fixed.
See my previous post for fixing the dash buttons triggering the wrong functions issue.
Old Jun 6, 2021 | 10:44 AM
  #205
toecheese's Avatar
Just looked on the Joying forum - people are still reporting issues with the firmware update breaking the Google login.
https://forum-joyingauto.com/showthread.php?tid=4255
Old Jun 7, 2021 | 06:57 PM
  #206
RussianHammer's Avatar
Top Answer: 1
Originally Posted by toecheese
Did you try switching the two wires for the dash controls?
I have my dash controls hardwired directly to the unit, no adapter at all. Everything except Mute programmed and works perfectly - Volume Up/down, Mode, CH. No issues.
didnt need to do anything. I just went into the headunits presets, and programmed the dash controls.
Old Aug 25, 2021 | 10:39 PM
  #207
toecheese's Avatar
anyone tried the new firmware yet?
Old Aug 26, 2021 | 06:23 AM
  #208
zrzrzrzr's Avatar
What version are you on? I just installed my Joying, and see MCU Version = 2021.06.24
Also if anyone was wondering if the 10.25" will fit in an AP1.
Old Nov 9, 2021 | 06:50 AM
  #209
toecheese's Avatar
Wondering if anyone has found workarounds for some of my gripes with this unit:
Displays completely wrong time when not connected to the Internet.
No voice dialing.
Incoming calls appear in an almost unreadably small font and also do not show names of caller even if the person is in your phone book.
Mic very hard to hear by person you are calling (I have mine mounted in the upper left corner of the windshield).
Old Nov 9, 2021 | 08:00 AM
  #210
slam126's Avatar
No voice dialing.
I have those same gripes. Joying told me the clock will update itself through the gps antenna too, assuming you can get a solid signal.
I’m curious, what model is your Joying head unit. I’m wonder if the newer head unit (JY-HQS01N4G-1 and JY-HQS01N4G-2) still have those problems?
