Android Single Din w/o Cutting!
Old May 4, 2021 | 04:39 PM
  #191
silenc3x's Avatar
Originally Posted by RussianHammer
I just got my 8.8 over the weekend, and i wanted to ask how you guys plugged it in? Did you splice your speaker/power wires directly to the harness they provide with it?
I believe my guys spliced into this harness which I had from another head unit:
Amazon Amazon
But I'll let others chime in.
Old May 20, 2021 | 08:12 AM
  #192
RussianHammer's Avatar
Top Answer: 1
I got the Joying Honda harness from their website for a plug and play setup, and what is surprising is that the dash volume control works. Well sort of; when you use the volume control toggle it raises the volume up.
I need to take a look into this to see what needs to be done to have it also lower the volume; however their harness seems to have alot integrated into it.
I thought i would also need something to angle my screen like the ones i have seen on this thread; although after sitting in my car how low my seats are. I did not need to make any adjustments.
Old May 20, 2021 | 11:48 PM
  #193
silenc3x's Avatar
If it truly is connected you can run the Control application on the Joying and rebind each button. You'll see the numbers jumping up as you push each button, to confirm they are working. See here, skip to 4:00:
I used the below adapter to make it all work.
Amazon Amazon
Old May 25, 2021 | 06:13 PM
  #194
Slapasaurusrex's Avatar
Originally Posted by AgentS2k
That makes sense, thanks.
I ended up designing and printing custom ones, but now need to find screws that fit since stock ones are too big:
Is there any way you could send me these files or print them for me? Ill pay! Thanks!
Old May 27, 2021 | 01:52 PM
  #195
Top Answer: 1
@silenc3x I am going to play with this, and follow up this weekend.
Old May 29, 2021 | 11:02 AM
  #196
Top Answer: 1
I followed the video and yes the dash controls do work on our car with programing them which took literally 1 min.
Old Jun 3, 2021 | 10:37 AM
  #197
toecheese's Avatar
Did you try switching the two wires for the dash controls?
I have my dash controls hardwired directly to the unit, no adapter at all. Everything except Mute programmed and works perfectly - Volume Up/down, Mode, CH. No issues.
Old Jun 3, 2021 | 08:08 PM
  #198
oth's Avatar
oth
I'd be careful about just experimenting with switching wires -
the dash switch wire goes to ground (-) while the mute
switch wire supplies +12v.
Old Jun 4, 2021 | 07:51 PM
  #199
slam126's Avatar
Look on this thread post #40. That’s how you get mute to work.
Old Jun 5, 2021 | 03:01 PM
  #200
d1000rr's Avatar
Originally Posted by silenc3x
That looks a great alternative and looks almost OEM. Definitely something to consider.
But that bezel is the same cost as the Joying unit by itself hahaha. And that sony unit is like $600. So definitely a more expensive route, but in the end you'll end up with better sound. Let me know how it goes.
The bezel he makes is $350?
So essentially it’s going to cost you around $1000 for a headunit going that route… damn
