Anyone Install a Viper Alarm Themselves?
Old May 24, 2013 | 07:33 PM
BLAQ&GREYs2k's Avatar
Default Anyone Install a Viper Alarm Themselves?
I have put in alarms before but the S2000 has a keyless entry module that functions by what many call "5 wire" door locks. I have concluded through research the DEI 451M unit is needed for install. It is essentially 2 SPDT relays wired for 5 wire systems in one unit. Has anyone installed one of these? My assumption from looking at the factory s2000 wiring diagram, is that i will have to cut the wires in order to have the lock/unlock function on my new viper alarm.
Experienced installers advice only please
Old May 25, 2013 | 08:06 AM
Originally Posted by AutoXs2KXx
I did one on my 2000 Civic Si, it was pretty easy if you have a simple understanding on how to wire a vehicle
DId you read my post? This is not a typical alarm install. I agree a 2000 civic is very simple because the door lock system is simple. This is what you have to wire up in order for the doors to lock and unlock.
http://www.the12volt.com/doorlocks/page3.asp#5w
Not to mention also having to wire a relay for the trunk pop to reverse the polarity. (alarm signal is - and the trunk pop solenoid works off + signal)
Again, only experienced installers advice please
Old May 25, 2013 | 04:39 PM
GrandMasterKhan's Avatar
If your lucky your S2000 will have a keyless module inside the dash directly behind the Start Button. you can ID it by clicking lock/unlock on your OEM remote. You'll hear/feel it click.
You will find two empty slots on the plug going into that box. Fish a wire in and tap it to ground. You doors will either lock or unlock. When you got which one is lock/unlock. Stick the wires in and secure them so they dont move. BAM. easy lock/unlock on the S2000.
Old May 25, 2013 | 06:24 PM
I am familiar with the keyless module, and I have the colors for the unlock - unlock + lock - lock+ wires. You said to fish a wire into the module and tap it to ground. Just the viper - trigger wire? Can you be more descriptive? Thank you for the advice, finally someone! Ive seen two methods done, 1 solder the wires from the viper to the keyless board 2. install a 5 wire relay system to lock unlock the doors. Our door actuators work off constant polarity which is switched from neg to positive when lock and unlocked.
Old May 27, 2013 | 09:52 AM
etang789's Avatar
You do not need DEI451M for s2000, just solder the (Door Lock, 3-pin Connector) on the Keyless Module PCB like in the picture.
Here is a Viper Alarm DIY Guide
https://www.s2ki.com/...larm-diy-guide/
Old May 29, 2013 | 05:00 PM
Sweet thanks! After scowering the internet for a couple more hours, it appears there are two empty pin slots on the connector to the keyless module. I unplugged the connector and there are two male pins behind them. I read 2 testimonies where it worked. I might do that instead of taking the module apart.
Old May 30, 2013 | 06:23 PM
Ah neat! I didnt know you could tap directly to the circuit board. I am glad I could help and you were able to figure it out, and sorry I coulnt give more details. Next time I do an alarm install i'll take a pic while i am in there.
Trbl s2k
Feb 27, 2013 02:08 PM
S2KCHRIS305
Aug 15, 2012 10:05 AM
S2K2XGA
Inland Empire S2000 Owners
26
Aug 25, 2008 07:55 PM
Arbeeezy
Apr 28, 2006 10:22 PM
MitchSF
Apr 23, 2006 10:55 AM
