Audio controls on dash
Old Sep 19, 2008 | 03:52 AM
xrapidx's Avatar
Default Audio controls on dash
My audio controls on the dash (with the Start button) are shorting something somewhere, and when plugged in, the radio sometmes comes on, sometimes doesn't, sometimes comes on while driving, etc.
I took it to an audio place who just unplugged the controls for me as they weren't sure how to fix it. After that everything worked fine, except I had to use the head unit to control everything.
I then took my car for a service, and asked Honda to check it for me, I told them it was unplugged and why, needless to say, the idiots returned my car after the service saying they fixed the audio controls, the reason it wasn't working was because it was unplugged...idiots.
Anyway, I'm now stuck with the same problem, is there quick way to unplug the audio controls?
Thanks.
Old Sep 19, 2008 | 06:59 AM
darkknight1999's Avatar
Yeah reach up there and unplug it again... its right up under the dash you can see it if you lay on the floor of the car.
Old Sep 19, 2008 | 07:00 AM
Did you buy the car used? and do you have an aftermarket headunit?
Old Sep 20, 2008 | 12:56 AM
xrapidx's Avatar
Used Car... but problem started a few months after purchase.
Stock headunit, I think it has something to do with the mute button, because when the unit is actually working, and I push "Mute", the entire radio turns off, it doesn't just mute, pushing it again turns the unit back on.
The other buttons, "Audio Control", "Volume" and "Channel" all work 100%, its just the "Mute" button.
Old Sep 20, 2008 | 01:29 AM
2JZS2K's Avatar
It could be a problem with the circuit board. I had a problem with mine that the mute button was stuck in the on position. I had to replace the whole unit to get it to work again. That's probably going to be your easiest fix. Look on the for sale section or ebay. They're everywhere and only take about 15 minutes to replace.
Old Sep 21, 2008 | 12:26 AM
xrapidx's Avatar
Yeah, thats what I've also been trying to do, except I have a RHD, so can't quiet find the controls on ebay... any idea what they're called to help in my search?
NickShawn
Apr 22, 2012 07:18 AM
jerseyvtec
Nov 3, 2011 04:18 AM
rob2.2
Sep 12, 2011 11:22 PM
ddutka
Aug 15, 2010 12:27 AM
MidnightSi
Feb 17, 2004 05:18 PM
