Audio Controls issue
Old Apr 21, 2012 | 05:32 PM
NickShawn's Avatar
Default Audio Controls issue
I recently bought a 2001 s that is bone stock.
The issue I am having is that the audio control buttons will work fine but then every 2-3 minutes or so the buttons will change their function.
By that I mean:
"Channel button" becomes "volume up"
"Volume up" becomes "volume down".
"Mute" remains the same.
"Volume down" mutes audio when pressed.
"Audio Control" does nothing.
I have a fleeting suspicion the audio control board is bad...I looked at the board and seemed fine but it may have a fried IC..even though its just resistors and capacitors..
OR it's a bad head unit.
The wiring is fine.
Has anyone else had this issue?? Or know what's going on?
Old Apr 22, 2012 | 07:18 AM
oth's Avatar
oth
The dash control is just a resister network - when you press a button the headunit is grounded through
the appropriate resister, and the headunit decides what to do based on the voltage through that connection.
You can test the dash controls with a multimeter - Modisfry's DCI tech page has a chart with the correct
resistance values.
xrapidx
Sep 21, 2008 12:26 AM
Otherguy
Nov 22, 2006 08:07 AM
naruto
Feb 23, 2005 10:40 PM
MidnightSi
Feb 17, 2004 05:18 PM
DJ Qube
Sep 21, 2002 08:25 PM
