Audio Interrupt In?
Old Jan 6, 2005 | 12:28 PM
Waterbug's Avatar
Default Audio Interrupt In?
Im going to instal an alpine HU into a boat and Im trying to put some sort of mute or volume control on the driver side (HU goes on passenger side).
The head unit has a audio interrupt in lead, which Im guessing is like a mute control? Im wondering what I would need to wire up a button to send the right signal to the head unit to mute it.
Thanks.
Old Jan 6, 2005 | 03:22 PM
ruexp67's Avatar
As with all things 12VDC, you need a switch that will either ground the interrupt wire or send it +12VDC.
My guess is ground. So I would wire a switch inline from your interrupt wire to a good ground. If that doesn't work, hook the wire up to a 12V source. (The ground is 1. Safer, 2. Easier to try, and 3. the most likely solution.)
Old Jan 6, 2005 | 07:25 PM
Waterbug's Avatar
ok, I'll give that a try.
Would a push button switch on first push mute it and then on the next push unmute?
Old Jan 7, 2005 | 05:27 AM
ruexp67's Avatar
You probably need a maintain switch. (Something that, when pushed, says pushed.)
Otherwise you could get fancy with a relay and stuff, but that would be more complex.
Old Jan 7, 2005 | 10:35 AM
smyroad's Avatar
You should be able to get a push-on push-off switch at radio shack.
Old Jan 7, 2005 | 10:44 AM
turbodriven's Avatar
From my SWI-X instruction book
S2000: On Acura/Honda20 plug, connect pin# 3 to the white wire of the SWI-X. The mute button supplies 12v on a yel/blu wire in pin#14 and latches on and off. Do not connect this to the SWI-X. If the aftermarket stereo has a "mute" input, use a relay to invert the yel/blu wire to a negative output and connect to the mute input of the stereo. If the mode button on the dash does not work properly, connect a 3.6k to 4k ohm resistor across the white end black wire of the SWI-X and re-program.
So yeah... it's most likely a negative input. The S2000 switches power to a relay which grounds the audio interrupt lead.
loftust
Dec 29, 2012 11:22 AM
TrackStar
Jul 10, 2007 07:29 AM
Otherguy
Nov 22, 2006 08:07 AM
ARMS
Sep 21, 2006 07:34 AM
burnmacs
Dec 12, 2005 03:33 PM
