Blaupunkt Saucer Subs
Old Apr 6, 2002 | 11:28 AM
pcloadletter's Avatar
Default Blaupunkt Saucer Subs
Has anyone heard these? Really thin and light. I think they might work in the rear deck while keeping the spare. The specs are from caraudio mag: the 10" weighs 40oz, 2 1/4" thick, 180-550 watts, the 12" dual voice coil weighs in at 20oz, 2 1/2" thick and can handle 400-1200 watts.
http://www.gspr.com/ODwp_Flat_Subwoofers.html
http://www.blaupunktusa.com
Old Apr 7, 2002 | 06:44 AM
shaner's Avatar
My next sub project will use 1 or two of these new Blaupunkt subs in the passenger compartment...
This summer...
While I have never been impressed with Blaupunkt products, these extremely thin subs provide a lot of mounting options.
Old Apr 8, 2002 | 06:44 PM
KaCee's Avatar
how about an under the driver seat install?... I emailed Blau for some volume requirements. Anybody else with some more info...are these available yet?
Old Apr 15, 2002 | 07:11 AM
I called the Blaupunkt tech line and they don't have specs yet. They said around June the specs and subs will be available.
Old Apr 15, 2002 | 12:34 PM
modifry's Avatar
Honorary Member
[QUOTE]Originally posted by pcloadletter
[B]I called the Blaupunkt tech line and they don't have specs yet.
Old Apr 16, 2002 | 07:32 AM
intendedaccel's Avatar
[QUOTE]Originally posted by modifry
[B]The specs will tell the tale, and hopefully these won't suffer the same limitations of other thin subs, which is less-than-average cone excursion.
Old Apr 16, 2002 | 05:32 PM
modifry's Avatar
Honorary Member
Originally posted by intendedaccel
Although on it's own this may be correct, excursion is almost totally controlled with box design. In a different box I'm sure the results would be better.
You are correct in that the achieved excursion is related to box design, but the allowable excursion is not.
You can limit excursion by box design, but you decrease the audio output correspondingly, unless you change from a sealed to a ported design. Ported designs typically give more audio output near system resonance, and do it with less cone excursion. But they also experience even more uncontrolled cone excursion below system resonance than a sealed system.
In order to keep that system resonance point low, so there would be little audio below it, I'd need a very large box. And in my case I'm trying to keep the box as small as possible. For this particular driver I'd need a 4" port tube 16 inches long, which is slightly outrageous in a 20 liter box.
dthondatune
Nov 3, 2006 12:03 PM
blacks2k
Jan 21, 2006 02:23 PM
Saki GT
Aug 17, 2005 06:23 PM
bkw
Jul 25, 2001 05:28 PM
BassMan
Apr 22, 2001 09:31 PM
