Sub behind passenger seat
Old Aug 16, 2005 | 05:38 PM
Saki GT's Avatar
Default Sub behind passenger seat
Ok, still trying to get a sub inside the cabin - I'd love to mount my sub under the driver's dash, but it looks like way too much $$$ to get done. I did see today something that intrigues me - its a custom box, almost flat, with a sub that can get by with little volume.
It basically looked like this:
It was a Solobarics L7 run through 350W in a full king cab Ford truck - no space behind the seats like the S - and it sounded good. Provided I can live without 6" of passenger seat travel, does anyone think this is doable? I was thinking of running an L5 for the same purpose, but I'm open to sub suggestions...
Figured I'd bring this up for discussion. Thanks for all your input,
Old Aug 16, 2005 | 06:02 PM
darkknight1999's Avatar
Sure you can put it back there... I just hope all your friends are 4 feet tall You better off just putting it in the trunk. Anything that's worth its weight that would work well in the cabin will require a fair amount of $$$. Its not like your trying to listen to the highs from the trunk... its bass tones... and the trunk is vented right into the cabin. You could do a footwell install, a custom center console, subs under the seat,... and so on.
Old Aug 16, 2005 | 06:39 PM
formulaofsuccess's Avatar
hmmm, my girlfriend is only 5'3" and 95lbs, she could probably get by with less leg room not to mention she's the only person that ever rides in the S.
i was wondering about a simple JL 6W-0, they are only 3.5" deep or so?
Old Aug 16, 2005 | 07:16 PM
kkyntmoon's Avatar
I used to use my gf as an excuse, Now I have nothing to say anyore. there is no gf =P
Old Aug 16, 2005 | 07:34 PM
Saki GT's Avatar
Haha, one of the reasons I got a two seater convertible was not to drive all my friends around. What's one less passenger? Maybe I could get a box that I could move between the cabin and trunk depending on which area needed the space - person or bags.
I'll probably go with Laurent's box though, its not like I have to fight through sound deadening in the S. DK1999 makes some good points.
Old Aug 17, 2005 | 07:39 AM
jwa4378's Avatar
what about the possibility of mounting 2 JL 6w0's in Lucid panels? I dont know if they are designed for free-air use, though.
John
Old Aug 17, 2005 | 09:49 AM
Well you could I suppose but you would have to build the panel out a lot. Here's a picture of the space behind those panels... there insist very much room. I fit a set of Alpine SPX-137a's back there but I had to cut some of the metal away just to make those fit...
I have more but this picture pretty much tells the story... your not going to fit much back there unless you do some custom work.
Old Aug 17, 2005 | 10:31 AM
dozen5's Avatar
don't know the whole story but how bout in the passenger footwell? says it's an 8"
http://forum.elitecaraudio.com/showthread....threadid=107572
Old Aug 17, 2005 | 06:23 PM
modifry's Avatar
Honorary Member
That's not a bad idea, it makes more sense to lose the leg room up front than in the back. Plus you can take it out if you had to.
You can save several inches of leg room if you do a custom install in the footwell, but it's not for the squeamish. Some pics of mine here.
lukedon
Jan 25, 2011 10:51 AM
crazylarry85
Jun 29, 2007 02:12 PM
dthondatune
Nov 3, 2006 12:03 PM
blacks2k
Jan 21, 2006 02:23 PM
bkw
Jul 25, 2001 05:28 PM
