can someone make a step by step footwell light guide?
Old Mar 2, 2004 | 05:57 PM
CyrusA's Avatar
Default can someone make a step by step footwell light guide?
I am looking to install footwell lights in my car this weekend using neons. Ive seen wiring diagrams and stuff when i searched and i saw a guide with pictures but it used modifry's system. Im trying to do this with spending as little money as possible. So can someone give me a step by step guide without that system. Where is this 12+ v source i gotta tap into. And then from there i still dont know what. So can you help me? Thanks
Old Mar 2, 2004 | 06:10 PM
LordMagnet's Avatar
I have a 12" neon going horizontally under the drivers footwell. I attached each end using zip ties around the existing wires under neath. I cut the car adapter plug off, stripped the wires and tapped into the fuse box.
I then hooked up a 10" neon to the passanger side. I set it up front to back and it's held using 3m double sided tape (has held up for almost 2 years now with no problem). There's a hole that you can put the wire through (bent metal coat hanger) to the drivers side and again wire it to the fuse box. Becareful to make sure that you wire it correctly so not to make it a fire hazzard.
Old Mar 2, 2004 | 06:15 PM
LordMagnet's Avatar
Sorry if that's not a technical step-by-step guide but it should help. Let me know if you need me to clearify anything.
Old Mar 9, 2004 | 05:32 AM
C45P312's Avatar
lordmagnet: where did you get the neon lights from? brand, price etc. list of parts? any pictures?
Old Mar 9, 2004 | 07:29 AM
MacGyver's Avatar
You guys could always wait until my Footwell Lighting system is finished....
Old Mar 9, 2004 | 09:51 AM
LordMagnet's Avatar
[QUOTE]Originally posted by C45P312
Old Mar 9, 2004 | 09:52 AM
Hickey322's Avatar
how about your underbody lighting?
Old Mar 9, 2004 | 01:31 PM
MacGyver's Avatar
Still working on it...
Old Mar 9, 2004 | 01:35 PM
AquilaEagle's Avatar
Administrator
Moved to Electronics
EOE
Jun 5, 2020 01:18 PM
DRE.
Jul 31, 2007 09:17 AM
s2kminator
Jul 14, 2007 07:39 PM
Mannn
Feb 5, 2004 06:48 AM
