Capacitors
Old Apr 28, 2007 | 04:52 PM
DDuds2k's Avatar
Default Capacitors
Ive read the faq and done some searches...basically are capacitors not really necessary in the S?
I have a 2000, and I think still using the original battery. It may have been replaced once, not positive.
Id be running a decent system, 2 amps, a 10w6 sub, components etc. But total ampage is probably goign to be right at 800watts where the faq said should be okay. a ~500watt alpine amp, and 300/2 jl. Would a cap be necessary?
Is this sort of a test it out and see what happens deal? Go without one first, and if lights dim..get one?
Old Apr 28, 2007 | 06:41 PM
darkknight1999's Avatar
You shouldn't need it if you have a good strong battery. If you have the stock battery you might see the light dim every once in a while. The good news is, is that you can add them in any time
Old Apr 30, 2007 | 01:10 AM
modifry's Avatar
Honorary Member
If your system is large enough to make the lights dim then you are exceeding the current capacity (as in amps) of the alternator/battery. Adding a cap may minimize the dimming but will not increase the power output of the total system. It's a sign that you may be better off with a higher capacity alternator.
Old Apr 30, 2007 | 02:57 AM
DDuds2k's Avatar
ah. The plot thickens. Thanks modifry
Old Apr 30, 2007 | 08:30 AM
other_vortechs2k's Avatar
It never hurts to add a cap...that is if you connect it correctly. It will help to smooth out any power spikes so it doesn't look like you have strobe lights in your dash. Plus, that 800W is maximum output power, so you have to keep in mind that some amps are less efficient than others and can take a lot more power to make that 800W.
Old Apr 30, 2007 | 10:39 AM
hoangcs's Avatar
where can you get better alternators?
Old May 11, 2007 | 03:28 PM
NFRs2000NYC's Avatar
Denso makes a direct 120A replacement for our cars.
DangerZone9K
Mar 28, 2012 07:40 AM
Grimnebulin
15
Oct 30, 2007 10:32 PM
REVZ TO9
Jun 1, 2006 02:57 AM
yoweichang
Nov 6, 2005 08:12 PM
mcomer
Sep 9, 2004 08:51 AM
