Check out the finished box
Old Apr 16, 2007 | 12:08 AM
RCHB's Avatar
Default Check out the finished box
ill get better pics in the daytime. i just finished 15 minutes ago
fiberglassed the entire tub, double baffled 3/4 mdf. the trim piece is two pieces in order to fit. havent measured the volume yet, but my guess is i have to stick some pieces of 2x4s in there cause i think there might be just a little too much space. time will tell though. the stock cd changer will go, just wanted to see how it looked.
my intro to the electronics forum. all work has been done by yours truely.
Old Apr 16, 2007 | 06:02 AM
VorlonDrow's Avatar
Beautiful!
Old Apr 16, 2007 | 04:34 PM
darkknight1999's Avatar
Look nice
Old Apr 16, 2007 | 05:10 PM
Looneybomber's Avatar
No need to fill it in if you have an excess of air space. It just lowers your F3 which is a good thing.
Old Apr 16, 2007 | 05:49 PM
itsmylittlebrothersbike's Avatar
Very nice!
Old Apr 17, 2007 | 01:03 AM
RCHB's Avatar
thanks for the complements guys.
amp install will be tomorrow, need to know how many feet of power wire i will need.
it will be in the place of the spare for now. im going to run a 0/1 gauge, getting ready for a two amp setup later down the road.
Old Apr 17, 2007 | 03:54 AM
Dave-ROR's Avatar
Depends on how/where you run the power wire, but 16 feet feet should be good, maybe 18 just to be sure. I either have 16 or 18 in mine running from the batt, across the engine bay, through the grommet under the brake booster, along the drivers side door sill (under the carpet/sill cover of course), then up under the soft top cover, over the fuel pump area, then down to the tool well. If you ran it down the pass side you could do it with a lot less cable, but the pass side is a great location to run signal and audio/speaker wires since there is no power wires over there normally..
Old Apr 17, 2007 | 07:04 AM
HankookS2K's Avatar
wow...beautiful...i love JL subs....let us know how that sounds!
subsoniic
Sep 23, 2009 10:32 PM
replicah
Jul 19, 2006 12:19 AM
koala
Jul 24, 2003 09:24 PM
nickhaines4
Apr 22, 2003 06:47 PM
StormBringer
Jun 12, 2002 09:14 PM
