Dead Radio
Old Feb 27, 2006 | 11:25 AM
RSXLNT's Avatar
Default Dead Radio
Turned the car on yesterday and no radio. CD doesn't work, nothing. Checked the fuse and it's ok. Even disconnected the battery then reconnected it. Still dead. It's weird that a radio would die so soon in a new car. Anyone else have this problem?
Old Feb 27, 2006 | 11:56 AM
xviper's Avatar
I believe there are 3 fuses that control the HU. You need to check them all.
Old Feb 27, 2006 | 11:57 AM
Cubs2k's Avatar
So which fuse did you check? #9, #23 and #24 all are used in the audio system.
Most people only check #23.
#9 is almost always the culprit.
Old Feb 27, 2006 | 01:19 PM
RSXLNT's Avatar
My owner's manual says that the radio is fuse #19 in the interior fuse box. It says #23 and 24 are for the right and left power window.
Old Feb 27, 2006 | 01:41 PM
Cubs2k's Avatar
[QUOTE=RSXLNT,Feb 27 2006, 05:19 PM] My owner's manual says that the radio is fuse #19 in the interior fuse box.
Old Feb 27, 2006 | 03:13 PM
RSXLNT's Avatar
... aahhh the accessory socket. Interesting. We were at the track over the weekend and I was using the accessory socket for my tire pump. Filled up my tires with air and then started using it to pump up my son's tires too. After one tire was done, I went to another tire and the pump didn't work. I figured the pump broke because it's just a cheap $20 air pump. Hmmm... perhaps it blew a fuse.
Thanks! The accessory socket is #5 on the AP2. I'll check it out.
Old Feb 27, 2006 | 03:19 PM
SheDrivesIt's Avatar
I'm sure that's it. Note that it is an "accessory" socket not a lighter socket so current is limited. Probably won't run your air pump.
Old Feb 27, 2006 | 03:29 PM
RSXLNT's Avatar
Hmmm.. what are my options for using my air pump. Is there a way to do it without blowing a fuse?
Old Feb 27, 2006 | 03:44 PM
xviper's Avatar
Put alligator clips on the airpump and clip them directly to the battery.
Old Feb 27, 2006 | 06:31 PM
RSXLNT's Avatar
Thanks guys. I really appreciate your help and advise.
jbird0007
Jun 21, 2011 08:43 AM
PokS2k
Jan 29, 2011 02:11 PM
kingbriani
Aug 13, 2007 04:13 AM
Heartless
Oct 14, 2005 07:35 AM
2k2S2000NY
Jul 2, 2002 07:21 AM
