Difficult Garage Door Mod
Old Oct 29, 2007 | 04:40 AM
Soulblade's Avatar
Default Difficult Garage Door Mod
Does anyone know how to use the popular garge door opener mod with one to the newer, advanced remotes? I have a Liftmaster 971 remote which modulates through billions(?) of codes and uses a 3V disk battery.
Thank you....
Old Oct 29, 2007 | 05:20 AM
MacGyver's Avatar
It has a button to press, right? Wire into the button with a relay. The battery voltage or number of codes it rolls through is irrelevant.
Old Oct 29, 2007 | 06:22 AM
webmasterino's Avatar
Is there a way to wire a garage remote to the car or do you all just use velcro for the remote or what? I'm not too keen on leaving the remote in plain site for security reasons. I had a buddy suggest the homelink mirrors but those are huge. Any other ideas?
Old Oct 29, 2007 | 06:25 AM
MacGyver's Avatar
In the past, I simply hooked the switch up to the brights through a relay... pull in, flash the brights, door goes up, flash 'em again, door goes down.
Old Oct 29, 2007 | 06:27 AM
HankookS2K's Avatar
if your remote is a 12v remote, then wire the power lead to your high beams or a switch of your choice and your good to go. i've also got this done on my garage
Old Oct 29, 2007 | 06:41 AM
MacGyver's Avatar
Originally Posted by HankookS2K,Oct 29 2007, 10:27 AM
if your remote is a 12v remote...
Actually, it doesn't matter if your remote is 12V or not, as long as you continue to use batteries... the relay isolates the remote from the car's electrical system.
Old Oct 29, 2007 | 07:55 AM
I like this method, can I be your grasshopper? I'm no E.J. but I am comfortable splicing wires.
Old Oct 29, 2007 | 08:28 AM
HankookS2K's Avatar
ahhh true that lol. when i did it i totally got rid of the battery and just wired the remote directly to the car's power source so i wouldnt have to worry about the battery no more.
I found wiring the button to be harder than just swapping power sources, but either way it works
Old Oct 29, 2007 | 09:31 AM
freq's Avatar
Buy mine.
The switch / button is already soldered in the "ON" position. Leads are soldered onto the battery connection and the (-) side already has a ring terminal for grounding purposes.
Zip-ties and half-taps included.
Old Oct 30, 2007 | 12:45 PM
Homo Sapien's Avatar
I bought a visor with a homelink transmitter in it off ebay for about $20 (off a Lincoln for my Subie, off a Maxima for the S). Wired it up under the dash, trained it with the garage remotes so now I can open either garage door and no remotes in the car. Using the third homelink button for my dad's house.
Emil St-Hilaire
Oct 22, 2015 11:49 AM
HAiRYANiMAL
May 10, 2014 01:20 PM
wonderd
Mar 19, 2009 05:00 AM
asn
Jun 6, 2005 09:34 AM
my2k2s2000
Jul 11, 2003 07:56 AM
