Do I need crossovers?
Old Jan 25, 2011 | 10:53 AM
Alphamale's Avatar
Default Do I need crossovers?
Or will the built in crossover capabilities of the amp be sufficient?
Here is what I'm running..
HU=Sony DSXS300BTX
Polk Audio Pa1100.5 5-channel/1200 watt
Amp Info...
Crossovers: The amplifier features built-in 12 db/octave crossovers which can be set to High-pass, Low-pass or Flat for the Front and Rear channels. The mono-subwoofer channel is always set to Low-pass. The High-pass filter attenuates low frequencies and is used with mid-range speakers and tweeters. The Flat setting does not attenuate any frequencies and is for full range speaker systems. The Low-pass filter attenuates high frequencies and is used for subwoofers.
Crossover Frequency: The front and rear crossovers can be individually set between 50 to 500 Hz, while the mono-subwoofer Low-pass crossover can be set between 30-250Hz to fine tune your car audio system
(variable high- and low-pass filters (50-500 Hz, 12 dB/octave) on 4-channel section)
Polk Audio DB651s
Infinity Kappa 10.9 tweets
Alpine Type-S SWS-1043D Dual 4 ohm
Ap1s2kay
Jan 14, 2014 04:42 PM
CeleSaga83
Jun 17, 2007 02:59 PM
littlerocket777
Mar 5, 2006 11:00 AM
jwa4378
Oct 16, 2005 05:20 PM
#22Benny
Jan 6, 2003 11:27 AM
