door speakers in a crx?
Old Sep 18, 2004 | 08:39 AM
2000celicaspeed's Avatar
Default door speakers in a crx?
Hey i got infinity kappa 6.5 inch seperates i am wondering if ti would be benifical to make an encolsure for the woofer? i am thinking a peice of pvc pipe6.5 inch in diamter and mdf on top and bottom and siliconed to make it sealed? would this make for better sound? or is this a awaste of time. the crx doors are very open and very roadnoisey
Old Sep 18, 2004 | 08:52 AM
bobby's Avatar
It would be a waste of time. You probably wont have much clearance between the magnet and the window/window track for an enclosure of any kind anyways.
You will not get any bass worthwhile from a 6.5 in a enclosure in the door anyway.
Just try and make sure you have a good baffle to separate the waves coming off of the back of the speaker cone from mixing with the waves coming off of the front of the speaker cone. If you don't, certain frequencies will cancel each other out.
Dynomat extreme works very well. Just cut a round hole in it just big enough for the rubber/foam surround, then place it over/around the speaker.
If you can construct something to keep the water off of the backside of the speaker you will get more life out of it as well.
Old Sep 20, 2004 | 05:34 AM
should i get some of those foam baffles?
Old Sep 20, 2004 | 06:28 PM
bobby's Avatar
yeah those work great. You may get better sound if you cut a hole out just behind the magnet. Just leave enough material for the water to deflect away from the speaker.
LookingForS2K
Apr 24, 2020 11:40 PM
RoG_Renegade
Aug 24, 2017 12:18 PM
99SH
Mar 18, 2008 02:50 PM
TrackStar
Sep 28, 2004 08:28 AM
Squeezer
Feb 15, 2001 02:28 PM
