ebrake - top
Old May 14, 2006 | 02:17 AM
fujimi's Avatar
Default ebrake - top
not sure if its a repost... but did anyone try to do a bypass of the ebrake so you can put the top up or down w/o the ebrake being up... or activated...?
tia
Old May 14, 2006 | 07:41 AM
jwa4378's Avatar
That is a loaded question.
I would strongly recommend leaving the e-brake control intact. What if you are riding with your friend on the Interstate with the top down, and he accidentally hits the "top up" button......kiss your soft top good bye.
I would recommend by-passing the speed indicator instead. This will allow you to put the top down while moving (not recommended at any real speed). All you will have to do is click the e-brake up 1 click (the pads are not even engaged at that point, but the ground contact as been made).
If you absolutely want to by-pass the e-brake control, you just remove the center console. You will see the e-brake. There will be 2 metal contacts. When the e-brake is engaged, these contacts are touching (I think this grounds a signal). You can just run a wire from the e-brake contact to the other contact so they are permanently touching. I believe this will leave the e-brake light on at all times, though.
Once again, I recommend by-passing the speed sensor, and just clicking the e-brake up 1 click. Wisconsin S2k wrote up something on how to do this.....check in the FAQ. If its not there, just PM him.
John
Old May 15, 2006 | 03:05 AM
Reborn56's Avatar
here you go..
https://www.s2ki.com/forums/index.php?showtopic=138773
Mark666
Oct 28, 2014 01:33 PM
whiteflash
Mar 9, 2013 03:36 PM
Nhan
Nov 20, 2005 06:29 PM
purdyS2K
May 20, 2003 06:24 PM
145
Jul 17, 2002 05:20 PM
