EPS Problem
Hi everyone,
My EPS problem is a bit weird and it is the same for 3 years now. In my country we couldn't find solution.
So here it goes;
The EPS light turns on if i start the car in cold weather, when i turn on and off the ignition it doesn't go away. Strange thing is when the engine temp becomes average and i restart the car it goes off!
Then, when i understeer it goes on again, in track if i touch the curbs, it comes on again. If i hit a pothole, it comes on again. It is not going worse or anything and the pattern is always the same. Especially in winter or in track it becomes a real big problem and i want to solve it now. Please help
Note: The car is AP1 so no VSA
So here it goes;
Very simply, you have a sensor issue. I cant remember the name exactly but there is like a torque angle sensor or steering angle sensor that monitors driver input. You need to bring it to a shop that has a Scan Tool. It will allow the technician to access the EPS module for any trouble codes. From there, you will have your answer.
constancychen
Jan 9, 2017 10:04 AM
