Garmin GPS hardwired finally
That looks amazing. Congratulations. What are your thoughts on trying this with the Garmin nuvi 5000? It has a 5.2 inch screen. If you think this could fit, I would definitely be in. Once again, good work, you may have opened the door to something here...
1) Recess the screen to prevent the vertical length of the panel from affecting the outer contour of the radio door
2) Match the screen to the flat surface of the radio door and mold out and around the bottom of the screen
With the first option, recessing the screen enough to accommodate the extended vertical length would require the radio to be back-mounted even further. I don't know if there is enough room for this. Using the second option, would mean trimming down the top edge of the radio door frame even more to make way for the larger protrusion. Since the edge of the frame is pretty thin, the frame would actually need to be cut all the way through, then rebuilt. Don't get me wrong, I like bigger screens just like everyone else, but with these challenges I have just been too chicken to buy a 5" Garmin for testing.
Well, sadly it's a no-go with the 7xx series nuvi. A right angle connector attached for the antenna increases the mounting depth too much, and I find relocating the surface mounted MCX connector is prohibitively risky. Additionally, wiring for the FM traffic receiver on the 765t is more complex than I would like since the 7xx series uses the docking style mount as opposed to the mini B usb connector. My final decision is to go with the nuvi 855t. Still crazy expensive right now, so maybe I'll start the next build when the price comes down.
On a side note, I tried using a re-radiating antenna to improve the accuracy of the 260w in the current setup and surprisingly it only succeeded in jamming the GPS signal completely. So much for that idea...
EDIT: I borrowed a friend's 7xx series nuvi to fiddle around some more with fitment, and can make it fit without additional cutting into the radio door frame. Yes, the right angle MCX connector will still take up some space behind the door, but it's not as bad as I had initially though.
Originally Posted by Ludeboye1,Feb 17 2010, 10:02 PM
Hey what did you use to cut the radio door, those are some clean cuts.
Also previously you didn't have any material around the cuts and in later pics it seems to be beveled out a bit.
Isn't the 855t too big?
Originally Posted by GregFarz78,Oct 8 2009, 12:23 PM
wow thats awesome I thought about molding mine into the visor
Anyone get a GPS unit to fit in the visor?
