Head Unit Wiring?
Old Oct 31, 2007 | 08:36 PM
mk84's Avatar
Default Head Unit Wiring?
Hey, Im gonna set-up my new system this weekend, I have 2x2 channel amps, 10 inch JL sub, 2 Bullet splits and a new HU....I took the hu off today but the wiring is hard to reach in that space and I cant really see where its goin, so I needed some help on how the easiest way to connect up the hu and which hole to run the leads from the battery and also where i can get the Harness adapter from somehere in Melbourne, Australia...Thanks Heaps
Tommy
Old Oct 31, 2007 | 08:51 PM
Will's Avatar
https://www.s2ki.com/forums/index.php?showtopic=248785
Old Oct 31, 2007 | 11:41 PM
TopAlwaysDown's Avatar
its not getting to the head unit and its wiring that was my problem, it was getting all that wiring and the head unit BACK that is a huge pain. such a small hole for such a large amount of wiring (especially if you went with a DCI adapter and a wiring harness so you didn't have to splice into the factory connection...
Old Nov 1, 2007 | 09:26 AM
mk84's Avatar
Still doesnt answer my question though
Old Nov 1, 2007 | 11:49 AM
Will's Avatar
1. Power - Your Amp power lead should run from the battery to a fuse block close to the battery, from the fuse block across the engine bay away from the battery and should enter your car on the right hand side of the engine bay under the brake master cylinder. There's a wiring grommet you can fit the wire though after making a small hole in it. Next run the power wire down the drivers side of the car (reason for this is most of the power leads in the car run to the drivers side of the car... ie: fuse panels, ECU, wiring harnesses, etc...) run it into the spare tire area and leave any slack on the power wire behind the drivers seat. (this should be minimal if at all) It should also go though anothor fuse block or fused distrabution block before you connect it to the Amp.
It was in the post I referred you to. As for a wiring harness, you should be more specific. Do you need a harness for an aftermarket radio, stock radio with split leads, etc...? You can get it from www.crutchfield.com, or perhaps suppliers more local to you would have them.
Anion
Jan 19, 2009 01:58 PM
impulse101587
Jun 4, 2007 04:52 AM
s2addict
May 28, 2006 10:17 AM
rasx
May 23, 2006 09:35 AM
Av8ing1
Jul 23, 2004 07:21 AM
