Help with 10W3D2's!! please help!!
Hi,
I was wondering what amp I should hook up to my 1 10W3D2. I was looking at the Phoenix Gold XS2300.. its specs are as follows:
2 Ch. 300watt XS Amplifier
4 ohm Mono 300 x 1
2 ohm Per Ch. 150 x 2
4 ohm Per Ch. 75 x 2
2 Channel Mosfet Amplifier
PWM Mosfet Power Supply
Defeatable, 24dB Per Octave Low Pass Electronic Crossover
Adjustable Twin T Bass Boost Circuit @ 45Hz
Advanced Overload and Thermal Protection
Hi Level Input Connections
Input Sensitivity Control
Advanced Muting Circuitry Eliminates Turn-On And Turn-Off Noises
Metal Film Capacitors/Resistors In Signal Path
24kt Gold Plated High Current Power And Speaker Terminals
Isolation Mounting Feet
is this a good amp to pair it up with? opinions? suggestions? comments?
thanks a bunch!
4 ohm Mono 300 x 1
thanks a bunch!
S2G-Unit
Feb 8, 2005 06:09 PM
