Help Deciding On The Right Speaker Replacement
Old Jan 22, 2002 | 11:22 PM
salsaweb's Avatar
Default Help Deciding On The Right Speaker Replacement
I heard and I liked the sound of these. I have the stock head unit.
Do I need to buy any other accessories and will they fit??? Does the '01 stock unit have enough power for these Polks?? PLEASE HELP!!!
Please help me choose between the POLK EX365 and the POLK dX6
----------------- POLK EX365 ----------------------------------------------
Mid/Woofer 1 - 6-1/2" Diameter (16.51cm)
Tweeter 1 - 3/4" Diameter (1.91cm)
Soft Dome Tweeter
Electrical
Overall Frequency Response 55-22kHz
Nominal Impedance 4 ohms
Power Handling (continuous) 60 w
Power Handling (peak) 180 w
Efficiency 92 dB
Install Dimensions
Driver Mounting Depth
Top Mount 2-1/16" (5.24cm)
Bottom Mount 2-5/16" (5.87cm)
Grille
Height 9/16" (1.43cm)
Diameter 6-1/2" (16.51cm)
Cut-out
Driver Cut-out Diameter 5-1/4" (13.34cm)
--------------------- POLK dX6 ----------------------------------------------
Polymer Composite Cone
Tweeter 1 - 1" Diameter (2.54cm)
soft dome
Electrical
Overall Frequency Response 50hz-20khz
Power Handling (continuous) 40 w
Power Handling (peak) 130 w
Efficiency 90 dB
Magnet Weight 10.00 oz.
Install Dimensions
Full-range Mounting Depth
Top Mount 2-9/16" (6.51cm)
Bottom Mount 3-1/8" (7.94cm)
Grille
Height 1-1/8" (2.86cm)
Diameter 7-3/8" (18.73cm)
Cut-out
Driver Cut-out Diameter 5-1563/10000" (13.10cm)
Old Jan 23, 2002 | 02:56 AM
lucid's Avatar
Yes the EX365 will fit without issue.
See this:
POLK EX365 Note
They sound very good on stock decks. I highly recommend you add the 340s for the rear and you'll be very happy with the results.
chrisgood1
Mar 11, 2010 08:21 AM
Putney
Sep 28, 2008 10:52 AM
Gantra
May 9, 2003 05:01 PM
salsaweb
Jan 30, 2002 03:10 AM
