help with door lock wires for viper 5002 alarm
Old Apr 26, 2010 | 10:31 AM
jonneson's Avatar
Default help with door lock wires for viper 5002 alarm
ok i been searching the forums,net, everywhere to figure this out but still have no clue . any help will be great .Thanks
Old Apr 26, 2010 | 04:32 PM
Stealth_SUX_'s Avatar
All your wires are at the keyless entry module:
Lock is pink/black
Unlock is yellow/green and pink/blue
These are 5 wire locks. So you can either use a 5 wire module or make one with relays.
And since there is two unlock wires, one for driver and one for passenger you will need two 5 wire modules.
The first one will do the lock and one of the unlock wires and the second will do the other unlock
Old Apr 27, 2010 | 06:13 AM
jonneson's Avatar
THanks , but i read that you don't really have to do the 5 wire you can run a wire out of pin 11 and 12 . is that true . what are you suppose to do with pin 11 and 12 after you connect wires to it ? do you ground it ? thanks again
Old Apr 27, 2010 | 01:14 PM
I heard that too, there are some people that have done that, I have no experience doing it that way so I do not know.
But someone else might be able to chime in..
BUMP
Old Apr 27, 2010 | 01:16 PM
wisdom's Avatar
Thats what i used for my clifford, ran the alarms lock/unlock wires into the open pins on the keyless and module it worked.
Good luck!
AP1Drew
Jan 19, 2012 04:40 PM
splatter85
Jun 17, 2009 08:08 PM
gatorsong
Jun 28, 2008 02:17 PM
ideugene
Apr 14, 2005 04:44 AM
jackdeth99
Nov 2, 2003 08:05 AM
