HELP! HU not working
Old Aug 13, 2007 | 06:42 PM
supraken's Avatar
Default HELP! HU not working
So I just put in a 'new' used HU that I bought from a fellow s2ki member. Put it in last week and it worked fine. I left the car sitting for a couple of days and when I first got into the car today, I noticed that it was not working. No lights, no CD eject, nothing.
I checked the wiring, everything seems fine, I suspected it was the fuse, but the plug that goes to the back of the HU is getting ACC, +12V. 12V outlet was also fine so I guess it's not fuse issue. Also checked the fuse on the back of the HU, looks ok and even tried swapping it. Nothing.
I'm out of ideas, but what else can be wrong? I mean the HU was working last time I was in the car, and today it's just dead? I'm really lost..
Old Aug 14, 2007 | 01:06 AM
DDuds2k's Avatar
Dont know if you used any wiring adaptors to twist wires together(hardwired?), but make sure none are "too" large and all connections are good. Try and use the proper size adaptors and see if this helps. I had a similar problem with mine, switched out a few of them, no more problem. If you are using a honda adaptor....might be a different problem.
Old Aug 14, 2007 | 04:14 AM
imdarkrider's Avatar
yellow on the aftermarket radio should be getting 12v constant , red should be getting 12v when you turn the car on , then black should be ground. Check all 3 of those. if there good , check the fuse that's on the radio - might not be there depending on manufacture. If all is good your radio is bad :-/
Old Aug 14, 2007 | 05:31 AM
supraken's Avatar
Can you explain a little bit more what this 'wiring adapter' is? I'm using the Honda adapter, twisted and soldered the wire ends of the wires on the adapter to the wires of the radio harness.. I re-did the constant 12V (yellow) and ACC (red).
The harness seems to be getting both.
The only thing I can think of is that the harness is getting a bad contact with the HU, or the ground is bad. I'll give it another check today..
Old Aug 14, 2007 | 05:33 AM
supraken's Avatar
That's what I'm afraid of.. and I just had this HU for a few days... sigh
the only thing that puzzles me is how it was working the other day and then just dead all of a sudden. I mean, just nothing, no noise no lights, absolutely nothing.
Old Aug 14, 2007 | 05:58 AM
he means a wiring hareness... if you used a wiring harness everything should be fine... if you cut the wires you should check to make sure everything is correct , and also make sure everything is taped good so that a wire isn't sticking out touching anything. check all your fuses inside the car too.
Old Aug 14, 2007 | 08:30 AM
supraken's Avatar
Any fuses I need to check besides the "Radio" fuse under the dash and the ACC fuse? (Is the ACC fuse under the hood?)
Actually, I didn't bother checking the ACC fuse since I tried plugging in a radar detector and the 12v outlet was working. I also measured the harness with a multimeter..
As a side question, Can the fuse be bad and let a certain (lower) voltage still pass through? Low so that it's not enough to power the HU, but still present a voltage reading at the harness.
Old Aug 14, 2007 | 08:53 AM
DDuds2k's Avatar
ya sorry, I did mean wiring harness for Honda, vs. if you just used the little tubes or twisties for tying wires together.
DangerZone9K
Nov 12, 2013 12:57 PM
loftust
Dec 29, 2012 11:22 AM
Rilot
Mar 18, 2012 06:15 AM
rubenzfst
Oct 20, 2006 02:19 AM
norcalskier
Aug 19, 2004 07:20 PM
