Help - Kenwood Head Unit Install Problems
Old Feb 2, 2009 | 04:55 PM
EggFart's Avatar
Default Help - Kenwood Head Unit Install Problems
Hi All
This is my first post to the forum, and I apologise if this has been asked before (I have searched for an answer...)
I tried to change the stock head unit on my AP1 so I can use my iPod. I bought a Kenwood U333 (I live in Japan) and tried to install it, although I'm a complete newb at this. The harness has standard wiring - Yellow (Battery), Red (ACC), Black (Ground), Brown (Mute).
However, the S2000 wiring is different. I found a wiring diagram and connected the Ground, then the wht/blu s2000 wire to the Battery on the Kenwood harness. No illumination on head unit panel but I can load/eject CDs. According to the s2000 wiring diagram, the wht/red wire is the ACC wire, so I connected it to the Red (ACC) wire, but still nothing.
I haven't metered any wires yet but can anyone please advise what the correct color wire (s2000) is for the Kenwood ACC wire.
Cheers
Richard
Old Feb 2, 2009 | 07:00 PM
Neutered Sputniks's Avatar
The two wires you need on the S' wiring harness are pins #1 and #2. I believe pin #1 is the acc and pin #2 is the antenna amplifier.
The yellow line should/can be run all the way from the battery (or the underhood fuse panel) or black to one of the screws on the side of the HU (one of the ones that screw into the chassis, not just the plastic).
Old Feb 2, 2009 | 11:12 PM
EggFart's Avatar
Thanks for the advice
Pin #2 is the ACC (wht/red) - I did have this connected to the h/u "ACC", at same time as having h/u "Battery" connected wht/blu S' Pin #10 (Constant Power), as well as Ground. Sorry for not having a clue, but where does the S' Pin #1Ant Amp connect to on the h/u as it only has, Batt, ACC, Mute, PCont (which the manual says is unused).
Thanks in advance
Richard
Pin #1 is the Ant Amp and
Old Feb 3, 2009 | 12:30 AM
Well, let me put it this way:
On my 05, I have 2 wires off the HU into the stock wiring harness - pins 1 and 2. Those are my ACC and Ant pwr wires...
According to the manual, Pin 1 is Yel/Grn to the Antenna Amplifier and Pin 2 is White/Red from ACC. Sorry, my earlier post had those two backwards.
There should be a "remote" or antenna output off the HU - a blue wire. If there's not, you can jumper between the ACC and the antenna amplifier. This will mean the Antenna Amplifier is on any time the key is in the "Run" position.
What other wires does the HU have? An orange illumination? That should be spliced to the ACC or to the stock harness Pin 19.
Old Feb 3, 2009 | 07:40 PM
EggFart's Avatar
Thanks again for this info
I'll have another go tonight at connecting everything up :-) There's no illumination wire on the HU, but there is a blue "remote" wire
Cheers
Richard
Old Feb 3, 2009 | 07:43 PM
If that doesn't work, can you take pictures of the manual and the Kenwood wire harness for me?
Old Feb 3, 2009 | 09:20 PM
Stealth_SUX_'s Avatar
buy a wiring harness adapter at any store so you stop hacking up your oem wires
plus all you gotta do is match colors once u get it.
MaxAP1
Aug 4, 2016 06:14 AM
Neuman04
Oct 17, 2011 05:41 PM
s2addict
May 28, 2006 10:17 AM
rasx
May 23, 2006 09:35 AM
2000silvers2k
May 7, 2006 07:56 AM
