help! NO Power going to deck!
Originally Posted by PJK3,May 28 2005, 01:09 PM
hrm.... amp turn on lead's will generally draw on the order of .1 amps or less (if i recall correctly) generally speaking though... even if it's 1 amp (it isn't), you shouldn't be blowing the fuse.
something isn't right. go back and double check all your connections.
this fuse is blowing for a reason... you shouldn't have a 10 amp draw on that fuse unless there's something else in that circuit you've not mentioned. don't upsize the fuse as of this point.
i truly appreciate it, after being on here for a while, i realize the crowd in general are very mature to enthusiast of all levels, unlike some of the local forums where they would just take every oppurtunity to bash.
i'll look it up tomorwo because i know that the remote going to the kenwood amp (existing amp that's hooked on the accesory) is also hooked onto another thing beside it, i think it's the ext. amp something
i'll check tomrorow, thanks again
alright i checked it out today and heres how they're wired for now
the accesory power is connected to three things, the red wire (acc. pwr to deck), power control, and ext. amp control of the kenwood amp.
When i also add in the remote from my rockford amp to the acc. power, the fuse blows
when i hook up the rockford remote wire to the power control in the harness for the deck, it doesn't work
can anybody help?
i'm thinking of unsawdering the power control from my kenwood amp and putting it on the power control wire (blue/whtie) of the deck, along with the remote wire from the rockford
would this solve the probleM?
plzz help as i am going insane!!
can anybody help?
alright the system is alright now
we ended up hooking the remote to illumination since further testing shows that the remote wire leading out from deck harness is malfunctional
thx for all the help
thx for all ur help
your solution has me confused -- you're tying into the illumination wire? so? your amps only work w/ the headlights on?
i'm now confused on how this is working at all....
