HELP! Radio causing subtle whining noise?
Old Feb 17, 2008 | 06:38 PM
Carson07S2K's Avatar
Default HELP! Radio causing subtle whining noise?
If the radio is on while I am driving, a subtle whining noise is present and increases in pitch as I accelerate. If I turn off the power to the radio, the noise disappears.
What could this be?
Old Feb 17, 2008 | 06:40 PM
zissis's Avatar
Sounds like your audio system is picking up interfearance from your engine. Possibly your alternator.
Old Feb 17, 2008 | 06:55 PM
HankookS2K's Avatar
do you have an amp? check your grounds. could be a ground loop, picking up alternator whine.
Old Feb 18, 2008 | 01:21 AM
Neutered Sputniks's Avatar
Yeah, chances are it's a bad ground.
Alternator whine is often caused by a bad ground. Make sure your grounding point(s) for your amp(s) are less than 4ohms to your battery's neg terminal.
Old Feb 18, 2008 | 04:39 AM
I have no amps at all.
Old Feb 19, 2008 | 09:27 AM
rsxtaci's Avatar
are you using an ipod? my ipod transmitter does this.
Old Feb 19, 2008 | 10:44 AM
nope. bone stock in the electronics dept.
Old Feb 19, 2008 | 11:05 AM
TrackStar's Avatar
Normally I would say a bad headunit ground- this case IDK
Old Feb 19, 2008 | 01:02 PM
Well, it is my dealer's problem when I take it in. This noise wasn't present before I picked it up last week.
The Loon
Jul 25, 2011 07:38 AM
ltgrazer65
Nov 14, 2010 03:03 PM
gbyrne
Jul 9, 2007 08:55 PM
CA_S2K
May 30, 2007 08:52 PM
hondaS2001
Nov 9, 2005 12:33 PM
