HELP! Radio causing subtle whining noise?
If the radio is on while I am driving, a subtle whining noise is present and increases in pitch as I accelerate. If I turn off the power to the radio, the noise disappears.
What could this be?
What could this be?
Originally Posted by HankookS2K,Feb 17 2008, 10:55 PM
do you have an amp? check your grounds. could be a ground loop, picking up alternator whine.
Alternator whine is often caused by a bad ground. Make sure your grounding point(s) for your amp(s) are less than 4ohms to your battery's neg terminal.
